It is currently Mon Aug 11, 2025 2:55 pm
 Post subject: Fret saw recommendation
PostPosted: Sat Oct 01, 2016 9:59 am
First name: D
Last Name: S
I've been using the LMI fret saw and after about 8 boards, it is getting pretty dull.
I do like the saw, it's pretty stiff and well made.
I need to replace it and looking for recommendations.
I may just order another.
Dan
wah
Wah-wah-wah-wah
Wah
PostPosted: Sat Oct 01, 2016 10:04 am
State: ON
It has been a while since I slotted fretboards manually, but when I was doing them by hand I used a Japanese fret saw. I don't believe LMI carries it now, but StewMac has one. It is more expensive but cuts way faster then the regular fret saw.
http://www.stewmac.com/Luthier_Tools/Types_of_Tools/Saws/Japanese_Fret_Saw.html
Josh House
Canadian Luthier Supply
http://www.houseguitars.com
These users thanked the author Josh H for the post: dzsmith (Sat Oct 01, 2016 10:14 am)
PostPosted: Sat Oct 01, 2016 10:30 am
Last Name: Kincheloe
Resharpen it. I use this one http://www.stewmac.com/Luthier_Tools/Types_of_Tools/Saws/Fret_Saw.html, and it was dull when new. One or two strokes on each tooth with a needle file and it cuts like butter.
These users thanked the author DennisK for the post: dzsmith (Sat Oct 01, 2016 11:01 am)
PostPosted: Sat Oct 01, 2016 11:04 am
Last Name: McDonald
City: Okanagan Centre
State: British Columbia
Zip/Postal Code: V4V2H6
I have this saw. Pax has a fairly good reputation as a saw manufacturer.
http://www.leevalley.com/en/Wood/page.a ... 63338&ap=1
These users thanked the author Bri for the post: dzsmith (Sat Oct 01, 2016 5:26 pm)
PostPosted: Sat Oct 01, 2016 11:11 am
First name: Alex
Last Name: Kleon
City: Whitby
Zip/Postal Code: L1N8X2
I have the same one. Works pretty good, and cuts on the pull, like a Japanese saw.
Alex
These users thanked the author Alex Kleon for the post: dzsmith (Sat Oct 01, 2016 5:26 pm)
PostPosted: Sat Oct 01, 2016 1:56 pm
State: ON
Just make note that the Pax saw is .021 and the other saws are .023" for the kerf. Some wire has a .025" width so you want to make sure the saw kerf matches (or is really close) to the fret wire you are using.
Josh House
These users thanked the author Josh H for the post: dzsmith (Sat Oct 01, 2016 5:26 pm)
PostPosted: Sat Oct 01, 2016 4:27 pm
If you wax the blade it helps considerable. I make a saw cut in a candle take about 5 stokes and wax it again.
These users thanked the author jfmckenna for the post (total 2): Alex Kleon (Sat Oct 01, 2016 5:31 pm) • dzsmith (Sat Oct 01, 2016 5:25 pm)
PostPosted: Sat Oct 01, 2016 5:17 pm
I never had a problem with the SM Japanese fret saw, but I thought the fret depth stop was trash. Cracked and broke. Maybe they have changed the material now, don't know. I got an awful lot of fretboards cut with that saw and it's still sharp. would take me around a half hour to cut 23 slots.
These users thanked the author Haans for the post: dzsmith (Sat Oct 01, 2016 5:25 pm)
PostPosted: Sat Oct 01, 2016 5:44 pm
Last Name: Sollod
I also use the SM Japanese fret saw and have been happy with it. It's much better than the saw that came with the jig. I didn't get the depth stop because I use it in my old style SM slotting jig. I also stroke the sides with an old candle and that keeps it from binding. Of course I don't do high production. If I did, then probably the way to go would be a jig on a table saw. At my rate of building the "by hand" method works just fine...
www.swiftcreekguitars.com
These users thanked the author sdsollod for the post: dzsmith (Sat Oct 01, 2016 6:15 pm)
PostPosted: Sat Oct 01, 2016 10:12 pm
I recently used my Lie-Nielsen dovetail saw to slot an ebony board. It was almost effortless. I'm so comfortable using the LN saw from dovetail work, and I really appreciated being able to slot a board with it.
These users thanked the author James Orr for the post: dzsmith (Sun Oct 02, 2016 9:13 am)
PostPosted: Mon Oct 03, 2016 11:59 am
First name: Rodger
Last Name: Knox
City: Baltimore
Zip/Postal Code: 21234
I also like the SM Japanese saw, it's much better than their other saw. I got the Japanese saw when my first SM saw got dull.
These users thanked the author Rodger Knox for the post: dzsmith (Mon Oct 03, 2016 4:43 pm)
Users browsing this forum: J De Rocher and 51 guests
